1 - 4 of 4 Posts
Recently was cleaning the front Sprocket after removing the cover noticed a play of the front Sprocket, the retaining bolts are tight, but sprocket rocks a little around the drive shaft, is it something to take care immediately please advice
This is normal. The front sprocket has some back and forth wobble build into the mounting design. As long as it's not rotating independent of the teeth on the output shaft you're good.
1 - 4 of 4 Posts
