1 - 5 of 5 Posts
Hey guys, I’m new to the forum and kinda new to riding. Would anyone happen to know the easiest access location to the RPM signal wire. Which is supposedly a solid yellow with a thin green stripe to it. I can’t seem to find it unless I pull everything apart.
Thanks
Try tracing wiring-bundle coming out of dash to 1st wiring-connector and looking at wire colours there. The tach has to get RPM signal from somewhere.
Did you find out this solution. I'm needing same wire
Note: To the best of my knowledge and I understand, the above components are very reliable, so maybe you try first to check the wires and that all connectors are clean.
1. There are no GEAR INDICATOR, there is only a Neutral Indicator:
44667
44668
44669
2. RPM SIGNAL WIRE LOCATION:
Maybe easier access in the European model -
without Evap Canister???
My model is European model - No ABS.
44671
44672
44673
1 - 5 of 5 Posts
