1 - 20 of 25 Posts
Moderator
Testing ...
The attachment is from my garage
OK attaching the picture didn't work, try this
http://imgur.com/a/dwh0y
OK at least the link worked.
All eight valves measured at or slightly below the minimum clearance. I was doing the clearance check at 15K miles, 1 K before the schedule calls for it to be done.
Now for the tale of woe about a missing micrometer that I took to Montana with the reloading gear and a couple of rifles for the oldest boy. Two of the eight valve shims are illegible. A replacement micrometer is due in Monday. I want to get Honda shims so if my dealership doesn't have all of them I'll order on-line once they are all measured.
Moderator
I figured out the problem. The window that you use for photo uploads does not open wide enough to show an upload button in the lower right hand corner of the image list box.
If you don't make the window much bigger (I'm using Chrome) you don't see the button and if the button is not clicked, there will be no picture.
this response is via the green 'reply' box as usual 'quick response' large box now doesnt work [admin via kiwi reckon my cookies need clearing etc].. reckon its worthwhile responding tho regardless of how the cookie crumbles..
Moderator
Testing the quick reply in the USA 40 miles north of Mexico.....
Comment
It seems to work here, shisoshin
I agree with the OP. This site is very hard to use. I am a member at multiple forums and this one is challenging to post. It takes forever to load and resets all the time. I don't use the site much due to this oddness. It hinders the ease of use.
Discussion Starter #11
specifically - I can only post photos from an external server (PIA).
I show that I have 1 Notification pending, but every time I click on it, it says that there is nothing there.
And I try and post in the forum complaint dept., and couldn't even POST!
And I click on Post Quick Reply, and nothing happens! I doubt any of you will even see this.
(that was Quick Reply. Lets see if Advanced will let me post this.)
And advanced does, but I should not have to go here.
Well, I can see your post and the board works fine for me so far most of the time (I sometimes can't edit my posts and will only get a blank box without my text to edit). makes me wonder why. Maybe it's because I'm in a different time zone and there might be less traffic on the server when I'm online.:confused:
Same, but I can on the 300 site. Odd. I wondered if it was because I'm a subscribed 'premium' member on the 300 site and not here. Also on this site it is so slow to do anything, but again I think it is because of the subscription that blocks all the pop up advertising for me on the 300 site and makes it snappier.
using small 'reply' box, this failure of 'quick reply' large box has been a faily recent event,, also attempts to use 'like' have no effect.. just tried cbr300r site, same, nothing with 'quick reply' works using 'reply',, also 'like' no response..
Discussion Starter #15
Notification link redirects to Subscriptions. My notifications are up to 2, now, but I cannot access them.
And I am going to try and POST QUICK REPLY, but I doubt it will work (Google Chrome/Win10). I will have to GO ADVANCED to make this post.
As I suspected, the quick reply just sat there doing nothing. Had to come to advanced.
Administrator
test
Edit:
Hey gang,
I tried the quick reply using Chrome on Windows 10 as well and I am not running into any of these issues.
When you attempt to post using the quick reply, what exactly happens? Does the screen reload as if the post has been sent, but nothing shows up?Or does nothing load?
Everyone who is running into the above issues listed, what browsers are you using?
As for the notification redirecting to Subscriptions, where on the site are you clicking the Notification link?
Richard.
Discussion Starter #17
test
Edit:
Hey gang,
I push the "submit reply" button, but it is as if I never pushed it. No wheel going round and round, nothing.
Richard.
Normally, I enter the site on the Active Topics section.
I just tried it (Notification link) on every tab at the top of the page, and they all redirected to Subscriptions.
Discussion Starter #18
Well, here I am, on IE (ugh - I feel like I am in MalWart), and everything works, albeit not smooth at all. I must have an extension on Chrome that the site does not like. Poo. Everywhere else I go, everything works.
Let's see what happens when I hit Quick Reply.
1 - 20 of 25 Posts
