1 - 20 of 26 Posts
Greetings highestdc5,
How much of the pavement are you planning on using ?
How fast can I take this right hand hairpin?it seems like I am always scared coming in to the corner.
25-30? Whatever is comfortable regarding the current conditions.
The good answer is as fast as you are comfortable with, no faster. As you gain experience you will find you can take the same corners faster and faster. What speed you should be able to go through that corner is irrelevant because my guess is you aren't doing it right yet.
Take my advice with a grain of salt because I have only been riding for eight months. I am just starting to feel very good in my turning ability.
We all have a tendency to dive right into a turn immediately. This is wrong, especially on a motorcycle. Notice where you have the most turning effort. I bet as you start seeing the exit, you find that you need to turn more. When you see the exit is when you would like to be more aggressive on the throttle. This means you need a later turning point.
Note the turning point you are using. Try moving it 3-4' down the road because this may help you make your apex later in the turn.
Another thing to try, because this is a multiple radius turn, is keep wide at the beginning, lightly turn into the turn, remaining wide until a point where you can make a nice tight arc, without adjustments, to complete the turn. That is your "real" turning point. That is how many of the tight turns in my area seem to be. They are similar to decreasing radius type turns. I think that is easier for cars because we all know how much they like to brake during turns.
The thing about real tight slow corners is it feels unstable and we just got to get comfortable with that feeling. Use the force and have faith that you won't drop the bike.
I'd guess that a good rider could take that turn at 35-40 mph.
Read the book or watch the video: Keith Code: Twist of the Wrist. I have already learned a ton from reading/watching this.
Discussion Starter · #8 ·
I've watched it like maybe 30 times its just hard to absorb all the proper technique all at once since Ive only started riding like three months ago. I'm learning it day by day though and you still forget some little things once in a while.
No problem man. Just practice one thing at a time. I focus on one thing for around a month. This month it's the two step (Code term), picking a turn point and really looking through the turn. You can't learn it all at once. Fortunately, we can practice nearly every day!
try the speed limit:D
I agree! However, this is still an interesting topic. Realizing that the internet is filled with so much garbage, I saw a video that said if the footpegs aren't scrapping, you've still got more lean/ability to make the turn. Of course, for a newbie--that's terrifying! And, more importantly, is it factually accurate if you have the skill/experience and the road conditions permit? Just curious--not planning on being a knee-dragger anytime soon. ;)
Yes it is factually accurate. A skilled rider can scape the pegs on an extreme lean. somewhere on this forum is you tube vid with a guy draggin his head..on purpose.
If there's a posted suggested speed. My general rule is double it plus 20km and that's the fastest you can take that corner. It works!
Note my speeds are in km so you might have to readjust for mph.
This is my favorite off ramp. I've so far been able to get up to 110kmh
It works in some areas. I could take you down some roads that are clearly marked and if you took the corners using your formula you'd fling yourself off the road at the very first corner.
Hell, I'd like no, love, to see you run the dragon and maintain the posted speed limit. ROLL VIDEO!
I'm not saying a noob could do it but it can be done at the posted limit on the dragon. If you are experienced enough.
uh huh.
How about a vid of me, zoned out, entering a gravel covered 15mph hairpin about 40? Ever slide a 650lb bike?
Notice how far my buddy Fred was in front of me and how fast I caught up to him before crapping my pants.
Puckered Sphincter | bungie4 on Blip
Just for a frame of reference, this is a run down US421 - The Snake I did a few years back. Were NOT blitzing it, just a nice pace. The important thing to notice here is lane position on the EXIT of a corner. Notice how it's very rare for us to get close to the center line unless we have a good view of the oncoming road way.
Their is a *HUGE* difference between a race line and a "stay alive" line.
EOM 09 - US 421, The Snake | bungie4 on Blip
There's a good book you can download from Amazon (read it on the free Kindle reader) called Total Control by Lee Parks.
Amazon.com: Total Control: High Performance Street Riding Techniques eBook: Lee Parks: Kindle Store
Chapter 8 goes into extensive detail on cornering (line selection), choosing your apex for the turn, etc. He diagrams a number of different turns including your hairpin, which is essentially a decreasing radius turn. The book is worth the $15, and I'm sure Lee will excuse me posting his diagram here, in exchange for the plug:
P.S. The last MSF course a riding buddy and I took, "Bonding with your Bike," did decreasing radius drills, using "lollipops." They set up cones, equal lollipop stick length, with smaller and smaller lollipops at the top of each. You would do avoidance drills on the way up the stem (swerve between the cones), then enter the lollipop and ride the inside of the cones at any speed you were comfortable. Each one in succession reduced the lollipop diameter. Great drill. Best part, is we were using *their* bikes, which happened to be new cbr250r's... ha.
Discussion Starter · #20 ·
Thanks.exactly what I needed.Is the green line better than red?or is it just a matter of choice?
1 - 20 of 26 Posts
