1 - 9 of 9 Posts
Well I was comin home today and it was wet out so when I turned in to my complex I lost control of the tail and the bike fell on the shifter goin about 1 or 2mph and the only damage i got was the shift bent alittle but now Im having problems shifting down it shift up perfectly but down suck it shift but I have try a bunch of times or I got to slow down before getin to a stop and cycle down the gear very very slow does anyone have any clue on what this might be any help would be great thanks
Have to use the [IMG ] tag
You'll have to get a new-
gearlever
gear lever monting bolt (If yours is binding the shifter)
Rod (Yours is bent)
Maybe someone here with the parts manual can advise the correct terminology & part numbers please?
Yup, a hammer and vise may fix the problem; just go at it gently. Also, a box end wrench works pretty well to straighten the "toe piece". This is a common fix with dirt bikes still using the OEM pot metal shift lever.
1 - 9 of 9 Posts
