1 - 4 of 4 Posts
I need help finding the end of a shift rod that’ll fit on my bike, the problem is it’s a aftermarket shift rod I believe and can’t find a replacement part anywhere online without having to buy whole new rearsets, anything will help, thanks. The rear sets on now are Arashi if that helps.
44403
Hi - go to your local hardware supplier and buy a Tap and die set, this will allow you to cut your own thread so the rod will fit, just remove the excess with a hacksaw - just remember once you start and remove excess you cant return or go back if you make a mistake...... Lots of Youtube vids on how to
good luck
1 - 4 of 4 Posts
