1 - 3 of 3 Posts
**SOLVED**Help with LED taillight install / wiring
**update**this is the answer
"You'll have to splice into the existing wires. You could strip the wires and use a wire nut but I've found the "posi-tap" connectors perfect for something like this. That's what I used. http://www.amazon.com/Lockitt-POSI-TAP-Assortment-connectors-10-22/dp/B00CMC5DII?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage
installing LED taillight on Honda CBR250R, right now I have everything working including the stock turn signals, the only thing that does not work are the integrated turn signals, which are the 2 wires hanging down. All the plugs are taken up, there are no free ones, how do I / what do I plug in to have both the integrated and the stock ones fire simultaneously?
1 - 3 of 3 Posts
