How can you tell if I have the typ of battery stated. Should I obviously post a pic. Man tbh you’re speaking foreign language 🤔😂. Thanks for the reply Danno! My bikes a 2012 and with 400 miles so I believe and assume everything is original as I bought the bike used and pristine condition, literally with manufacture plastic sticker covering on different parts of the bike. So not sure if I even have the either type of batt mentioned.It should connect to drain-port of battery. If you have AGM or newer-tech battery, they don't have drain-ports, so you can remove that hose.
