CB 300R
Honda representative in the category "street sport naked" wins 300cc engine and striking design inspired by the world's top models naked Honda.
Its aggressive lines and sophisticated look convey sportiness and strength. The engine, with larger cubic capacity, provides more exciting driving performance both on and urban use for daily transportation, as roads, for leisure on weekends. These are just some of the attributes of CB 300R, which comes to Honda to expand operations in the segment of medium capacity and meet the demand from fans of the CBX 250 Twister, plus users online CG seeking greater differentiation and evolution, as well as new fans of the Honda brand and the world of two wheels.
According to research conducted by Honda, in Brazil, there was great anticipation around a brand new motorcycle that looks larger and that would provide even more adrenaline. Based on the desire of those users, Honda developed its new representative in the category "street sport naked".
The first wish was granted with the application forms of striking, inspired by the world's top models naked. The second was possible with the adoption of a larger displacement engine. Given its major competitors, CB 300R stands out for being the only category with propellant 300cc with twincam head on, and to use feeding system for electronic fuel injection PGM-FI.
CATEGORY
Street Sport
MOTOR
DOHC, 291.6 cc, 4-stroke, 4-valve, air-cooled
MAXIMUM POWER
26.53 hp at 7,500 rpm
MAXIMUM TORQUE
Kgf.m 2.81 at 6,000 rpm
BORE X STROKE
79.0 x 59.5 mm
FEED
Electronic fuel injection PGM-FI
COMPRESSION RATIO
9.0: 1
LUBRICATION SYSTEM
Forced by pump trochoidal
IGNITION SYSTEM
electronics
BATTERY
12V - 6 Ah
LIGHTHOUSE (HIGH / LOW)
60/55W
STARTING SYSTEM
electric
TANK CAPACITY
18 liters (3.0 liters reserve)
ENGINE OIL
2.0 liters (1.5 liter for replacement)
TRANSMISSION
5 speed
FINAL DRIVE
Chain with O-rings
CLUTCH
Multidisc in oil bath
FRONT SUSPENSION
Telescopic fork with 130 mm travel
REAR SUSPENSION
Monocushioned with 105 mm stroke
FRONT BRAKE
Single disc of 276 mm diameter
Caliper double piston
REAR BRAKE
The drum of 130 mm diameter
FRONT TIRE
110/70 - 17M / C (54H)
REAR TIRE
140/70 - 17M / C (66H)
CHASSIS
cradle semiduplo
SEAT HEIGHT
781 mm
MINIMUM HEIGHT OF SOIL
183 mm
DIMENSIONS (L x W x H)
2085 x 745 x 1040
BETWEEN AXLES-
1402 mm
DRY WEIGHT
143 kg
COLOURS
Black, red, yellow and white
CATEGORY
Street Sport
MOTOR
MAXIMUM POWER
MAXIMUM TORQUE
BORE X STROKE
79.0 x 59.5 mm
FEED
COMPRESSION RATIO
9.0: 1
LUBRICATION SYSTEM
IGNITION SYSTEM
electronics
BATTERY
12V - 6 Ah
60/55W
STARTING SYSTEM
electric
TANK CAPACITY
ENGINE OIL
TRANSMISSION
5 speed
FINAL DRIVE
Chain with O-rings
CLUTCH
FRONT SUSPENSION
REAR SUSPENSION
FRONT BRAKE
REAR BRAKE
FRONT TIRE
REAR TIRE
CHASSIS
cradle semiduplo
SEAT HEIGHT
781 mm
183 mm
2085 x 745 x 1040
BETWEEN AXLES-
1402 mm
DRY WEIGHT
143 kg
COLOURS
