1 - 5 of 5 Posts
So far these are the specifications im aware of for the CBR250R, if you have any please share.
Engine Type: 249.4cc liquid cooled single cylinder four stroke
Induction: PGM-Fi 38mm throttle body
Ignition: Computer controlled digital transistorized with electronic advance
Valve Train: DOHC four valves per cylinder
Transmission: Six-speed
Transmission gear ratio:
1-speed 3.333
2-speed 2.118
3-speed 1.571
4-speed 1.304
5-speed 1.115
6-speed 0.963
thanks for posting the info. thats a pretty short first gear. i wonder how usable that would be considering you would barely use it. any more specs? like what size tires they come with from the factory, whats the wet weight and dry weight of the bike, or mpg and tank size?
Heres more specs. Pretty much everything technical about the bike. The specs above was lacking some information so i decided to add everything in.
Sales name CBR250R
Model type Honda MC41
Overall length × Overall width × Overall height (m) 2.035 × 0.720 × 1.125
Wheelbase (m) 1.370
Ground clearance (m) 0.145
Seat height (m) 0.780
Curb weight (kg) 161 (STD) 165 (ABS)
Riding capacity (No. of people) 2
Minimum turning radius (m) 2.5
Engine type CS250RE, liquid-cooled 4-stroke DOHC single cylinder
Displacement (cm³) 249 Bore × Stroke (mm) 76.0 × 55.0
Compression ratio 10.7
Fuel supply system Programmed fuel injection system (PGM-FI)
Starter type Self-starter
Ignition type Full-transistor battery ignition
Lubricating type Wet sump
Fuel tank capacity (L) 13
Clutch type Wet multiplate with coil springs
Transmission type Constant mesh 6-speed return
Transmission gear ratio 1-speed 3.333
2-speed 2.118
3-speed 1.571
4-speed 1.304
5-speed 1.115
6-speed 0.963
Reduction gear ratio (primary, secondary) 2.808 / 2.714 3
Caster angle/Trail (mm) 25º00´/ 95
Tire size Front 110/70-17M/C Rear 140/70-17M/C
Brake type Front Hydraulic disk Rear Hydraulic disk
Suspension type Front Telescopic Rear Swing arm (Pro-link suspension system)
Frame type Diamond
1 - 5 of 5 Posts
