Lets see if i can think of anything....
How about a new more comfortable stock seat ?...
a better/louder,meatier sounding muffler ?..
I wouldn't mess with that, it's perfect for the target market and the thumper sound is annoying.
a transmission that doesn't get stuck in neutral constantly ?
Mine is never stuck but if the gear set isn't lined up with the input shaft then you have to let the clutch out a tiny bit to get it to turn just enough to slide into gear. I'm told this is normal for a bike by anyone that's owned one.
a windscreen that doesn't direct wind right at your chest & head ?...
It wouldn't be so bad but I like the look of the short one
a first service that doesn't cost $300 ?..
Better not buy a 4 cylinder bike lol, 300 is pretty cheap for what they have to do if it's out of adjustment.
more storage space under the rear seat than just enough room for a pepsi
can and the manual no one knows they have or dont bother to read even when they do ?..
Definitely if they can do it w/o making it obvious!
a fuel gauge that doesnt flash to tell you that you are on empty then you can only squeeze 2.4 gallons into your 3.4 gallon tank when you fill up ?
It is a bit strange, and oddly mines not always consistently low at the same point. Not sure if this will be addressed or not but it's not that big of a deal for me. Unless they meant us to run it till the bar disappeared.
Not putting a 250 sticker on each side of the side of the bike or at least not make it impossible to remove if they do ?
Nobody ever notices mines a 250 lol. I get so many compliments on it.
Buttons that actually work on the dash and dont have to be pressed extremely hard repeatedly to get broke in first before they do ?
This is annoying, it gets better the more they are used but mines still a little buggy.
No more BB in can rattling sound at and over 5000 RPMs ?
This is a problem and I'm sure there will be a TSB on it soon, I just wish it would be fixed under warranty since it is obviously a loose wire/connector rattling under the fairings somewhere.
I could keep going..but i'll stop here...lmao .I actually love the bike..but its far from perfect. good luck on that lottery ticket...i would go for a VRF 1000 tho...they have the CBR250R body style
