1 - 2 of 2 Posts
Hello guys,i have noticed small problem with my ignition after the service of my bike. Sometimes mostly morning, Turning on the ignition key works fine,but the display suddenly turns off and if i just give small pressure to the key it will come and fuel pumb will start ,the their is no problem.but i have noticed it sometimes,and want your advice what to do next.will wd 40 helps?
And if a turn on the engine kill switch at the time when i turn on the key it will go blank sometimes
I would try something other than WD-40. WD is "Water Dispersion" and isn't a lubricant. Search for some info about lubricant for locks is what I would suggest. A lube may help if something is sticking, but not if there is a wiring problem at some point.
Does it start (crank over) quickly when you start it?
I might also check your battery voltage and terminal connections just to make sure that's fine.
1 - 2 of 2 Posts
