1 - 7 of 7 Posts
Hi,
I've had my CBR250r 2011 (2nd owner) since 2014 and it's at 35k miles.
I'm unable to post in other forums for some reason so I'll post my issue here:
I'm in Southern California and this morning I took my moto out after not riding for a while this winter. It was the first time I red lined in 2nd gear and I was very worried about riding above 70 in 6th on the highway. Normally I would get close to red line around 80 in 6th gear, but today I was already hitting the limit near 70. What is going on??
Have you tried injector cleaner?
BTW, you have to start here before you can go to any other forum topic; this is meant to reduce spam.
Hi Mersine and welcome.
To me it sounds like your clutch is slipping. Did you change your oil recently? IIRC the clutch is in the oil and wrong types of oil can cause it to slip.
They won't. I was still sleepy when I did your why can't I post.
Slipping clutch is a reasonable cause for higher revs at same speed. This is usually noticed first in the highest gear (6th in this case).
Hi,
Referred to the OP.
BTW, are you sleepy?
1 - 7 of 7 Posts
