1 - 20 of 39 Posts
My bikes key will not unlock the bikes ignition. I push down on it and it won't turn right or left.
What can I do to fix this?
I am thinking of spraying wd40 on the key ,should I ?
Spray it on the key. Can't hurt. Do that up here occasionally. Good for dust and ice.
Sent from my crackPhone using MO cræsh Free
This has happened to me a couple of times I didn't use WD40 (I would have if I had some at the time) I just stopped cause I was sooo frustrated, both times I waited a few mins and when I went to try it again it worked!? Next time I will use WD40.
Unock the ignition or the forks?
Insert the key and wiggle the bar ends.
Discussion Starter #5
I did wiggle it and it did unlock the ignition but now it is stuck in the unlock postion and won;t release the key from the ignition lock. I used something called " 1 in 3 "that lubicant that oils cleans and lubicates. It still is doing the same stuff. If and when I do get the key out, then the key does not want to go back in.
I guess I will have to take it to the dealer. I called them today after I wrote this post and the service department said to wiggle it too but I have to wiggle it for a few minutes to get it to do any thing. That I know is not normal.
I normally use graphite on locks. Just a tiny spry of graphite powder. You can make do by scraping a soft lead pencil and collecting the powder on a sheet of paper.
Discussion Starter #7
thanks Jsonder. I will try that if I ever get the key to release from the ignition. I brought this brand because of Honda quality, so this is really not good. My Motorcycle only has 1500 miles on it as if this writing. I can leave the key in the ignition for now since I lock it in my shed at nights, but I cant go anywhere and leave it with the key in the ignition like this.
Does anyone know If I take this to the dealer, under the warranty ,do I have to pay just a 100.00 dollar deductible or is none under so low miles?
I think something broke off inside the ignition.
Unless the key is broke off in the ignition I would say it is definitely a warranty item, and should not cost you anything. Have you had the bike more than a year? Do you have extended warranty?
Discussion Starter #11
Just a thought, you have to push down on the key to release the steering lock, but if you continue pushing down after that point, the key will not turn on the ignition.
I am pushing down when I try to get the key to release. I had problems with this on and off, but today is the first day it has been this bad.
I also dont push down that I realize of when I turn it on and all the lights lite up.
Discussion Starter #12 (Edited)
No both keys are fine. When I couldn't get it to unlock the ignition at first, I look at both of my keys and I didn't see nothing wrong with them. I only have had the bike for less then 3 months, I brought it new in the middle of June and the Bike has 1,514 miles on it as of now.
I did buy the extended warranty, I remember the Finance lady saying something about a deductible on my warranty, I guess that was for the extended warranty then.
I would hate to have to fork over 100 dollars for the warranty when the bike is brand new to get my bike fixed for something like this . It would be one thing if I did it but I know both keys are fine but even at that, A key shouldn't break in the ignition , unless one of the two are made cheaply.
I drive a car, school buses, coach buses etc. I know how to use a key in a ignition lol.
Well I guess it looks like my bike is going to the dealer monday.
This can happen to everything and anything regardless of reputation.
Discussion Starter #14
Your right but it is disappointing because of Honda having such high quality reputation , I just expected nothing to ever go wrong. I guess you can't believe all the hype. Well I just hope this is my only problem with this motorcycle.
I also found out there is no deductible on the warranty so that is good. I look it up on Honda motorcycle website, there is not even one on the extended one, I have no ideal why that finance lady told me there was a 100 dollar deductible.
try to use your spare key and see if your ignition is not the problem... it might be your key, i had this problem too my key was just slightly twisted which restricted it from turning and ejecting the key
sounds like more than a typical tight fit etc.. after overnight rain [she lives on the street due to zero parking] months ago we had similar very tight non-functioning
ignition key.. as first response sprayed wd40 into it and onto the key..
waited ten mins and key went in easily then after a little moving around
returned to normal use.. if that wd40 fix doesnt solve your problem
then you must seek professional help, first from honda..
incidentally, after losing a key the local locksmith made up two more
for me on bike blanks for $8 each.. they seem stronger anyway
and havnt had the same problem at least not beyond a little tightness..
also, during that period including raining, i also placed a jar lid
from a medicine bottle onto the ignition/steering lock,
with a bit of bluetack to stop it being blown off by wind..
i wouldnt be paying anything if its beyond wd40 level problem..
Are you sure it's your bike, and not that CBR600RR parked next to it :D...I have been tempted to try that with a nice black CBR600RR at work - hey my CBR250R is black too and anyone could make that mistake right? And if the key fits, it's mine right?:rolleyes:
Sorry for being unhelpful :). But once ya have tried WD40, I'd think twice about putting a dry powder lubricant in to soon on top of that oil based lube.
Dave
Discussion Starter #18
"It does it with Both Keys"
It started though with this problem when I used the spare key.
At first the key would not turn in the ignition to unlock it and after I spoke with the honda service person who said wiggle it, it unlocked the ignition but then it would not release from the on postion. I had to wiggle it again to get it to release the key .
After I got the spare key out, I look at both keys to see if the spare key was broken or chiped. both look the same so It is not the key that I can tell.
I then put my regular key in the ignition and it would not turn the ignition on again to the on postion , I had to wiggle it hard back and forth before it turn the ignition back on.
I met a friend at five guys burgers and it came out with no problem. I came back after eating and I used the spare key and again it would not unlock the ignition, after I wiggled the key it unrelased the ignition.
Now I can not get it out of the on postion no matter how much I wiggle it.
I also have sprayed wd40 on it and anther lubicant called 1 in 3 which cleans, oils and lubicates.
Discussion Starter #19 (Edited)
update ,it is working now
I just went out to my bike and at first the key would not release then I got it to release and I used my regular key and it is locking and unlocking the ignition now with no effort.
Maybe spraying that WD40 on it last night loosed it up after setting over night?
I also wonder if the spare key was bad? I am looking at both keys and I don't see nothing broke or chipped on the spare key, but I am not using the spare key no more since this problem started with the spare key. I mean it did it with both keys but it started with the spare key. Maybe something broke off on the spare key and has fallen down now where it is not restricting the inside of the ignition???????
I hope this problem does not come back :( but for now it is working :)
I AM SO HAPPY, MY BABY IS BACK :)
See? And there you were questioning Honda quality...the darn things fix themselves!
1 - 20 of 39 Posts
