A simple replacement of a damaged plastic cap on my left crankcase cover is turning into a nightmare.
First of all, does anyone know how to remove the larger silver plastic cap in this picture without scratching or damaging the paint on the left crankcase cover?
I've tried just about everything I can think of and it just won't budge. Worse, I'm starting to damage it. The replacement cap definitely has threads and screws in, but even the tools I'm using that fit the slot perfectly just won't loosen the darn thing.
The cap is part is #7 in the diagram below (shown with a HEX slot, which would probably make things a lot easier. Unfortunately mine just has a straight concave slot on it like in the picture):
To make matters worse, I stupidly started to remove the crankcase cover itself (I know...what was I thinking?) until oil started dripping. I only lost about a half a cup before I was able to tighten the bolts up again, but now I'm thinking I'll probably have to drain the oil and replace the crankcase gasket now that it's been saturated with oil, right?
