How many km on the engine?
just under 7000 mi so about 11,000km? dealer gave me 10w40 at 600mi service, I switched to mobil 10w30 semisynthetic at 4000mi which ran well and then just switched to the fullsynthetic respol two weeks ago. It started off running really well with the repsol but got progressively worseHow many km on the engine?
My first thought is: coincidence. I'm thinking there's something else going on and your performance issue has nothing to do with the new oil . . . .just under 7000 mi so about 11,000km? dealer gave me 10w40 at 600mi service, I switched to mobil 10w30 semisynthetic at 4000mi which ran well and then just switched to the fullsynthetic respol two weeks ago. It started off running really well with the repsol but got progressively worse
I am 90% sure it is...I have asked myself that too but I don't want to drain the $40 of oil I just put in it lol. I have OEM filters that are etched with which way to put it, and I remember being pretty aware of it.got to ask the question. is the oil filter in the right way?
I posted this in another thread a few days ago, in reply to a similar question:I am 90% sure it is...I have asked myself that too but I don't want to drain the $40 of oil I just put in it lol. I have OEM filters that are etched with which way to put it, and I remember being pretty aware of it.
Do you think if I drained the oil into a clean pan I could put it back in? This has driven my curiosity to check...
I think this may be the problem. There are no bubbles now but I still think I may have too much in there, possibly from not letting it drip completely out on the change. As long as I go by what I see in the sight glass It should be okay. I would think less would be better than more in this case, if I had to choose onei'm not sure about how bikes are set up but on a car, if you have too much oil the crankshaft will splash in the oil and rob the vehicle of power. Hight end car engines have a windage tray which stops oil from splashing onto the crankshaft. The crankshaft will also cavitate (bubble) the oil which will drastically reduce its ability to lubricate the engine properly.
I would agree.As long as I go by what I see in the sight glass It should be okay. I would think less would be better than more in this case, if I had to choose one![]()
Thanks, but I am aware of that much. you wouldn't get very far checking it on the side standNever check or add oil with the bike on the side stand. It should always be standing straight up when you check it and add it.
