1 - 3 of 3 Posts
So i am planning to upgrade my brake system. While keeping the stock caliper.
What size should i go with the front. 14mm or 17mm ?
And for the back, is 14mm enough ?
Also, any idea what's the stock master brake size for front and rear ?
Thanks.
Not sure what you are after???
What measurable result will come out of this so that you can confirm you “upgrade” was effective?
Well, i am thinking to change the rear master brake pump with this.
44506
Is 14mm rear master brake pump enough ? Or CBR250R already use 14mm master brake pump.
As for front, i am considering to use this.
44507
14mm radial master brake. Is the stock master brake size 14mm ?
Like the title says. I am considering to upgrade the brake system. But still using the stock caliper.
1 - 3 of 3 Posts
