1 - 6 of 6 Posts
I know these have been mentioned in some other scattered threads, but since you can never have too much redundancy . . . . :)
1) In Seattle, 300 and change for the first service. They did find some valve clearances out of spec and adjusted them. Labor costs in the Seattle area are a little steep!
2) Bike does seem to run smoother, with more even power application across all gears, even a bit more get up and go. Clutch seems smoother as well, I understand that they inspect / lube the control cables on the first service, both my brake and clutch levers seem easier/smoother to operate.
3) I had the frequent (every 2nd or 3rd start-up?) stall-after-starting, never while riding as some have described. That is gone now after service, completely eliminated.
4) It seems a lot happier running up through the higher RPM levels now before shifting. That may be from more break-in, from my own learning curve, or from engine / clutch adjustments. I suspect all three!
All in all, it's a little pricey for the first service but I think it's well worth it. DIY some of the other work down the road if you wish but the bike runs better than ever, significantly so in some areas.
They didn't say and frankly I was just happy to get the keys back - missed my baby!
My understanding is is that the fuel injection system / idle speed may have some connection to the stall reason. Not sure if they made any adjustments there, or perhaps with the valve adjustments there's a difference.
I've also read from many here that the start-up stalls start going away with more miles.
At any rate we're in good shape now !
1 - 6 of 6 Posts
