installed low tone fiamm horn [$17 fm amazon to aust incl shipping]
using spanner fm toolkit [plus plyers to slightly bend stock bracket]..
had to worm fingers up to slightly release wire to horn, plus bend
contacts of horn upwards to connections and with horn downwards..
took 15 mins on the street.. used stock spring washer to new horn..
new horn is louder, but not offensive.. nice strong lower tone,
from 'beep beep' to 'burp burp', like a large car or small truck..
very happy with this horn based on low price, no fuss install
[virtually replacement] extra sound power plus nice note..
only slight bending of stock bracket in situ gives tight
fit, just touching rim of fairing side panel, so inserted
soft rubber between horn and fairing.. seems secure
and probably adequately insulated fm vibration..
[if you have workspace etc, recommend removing tank
and fairing side panel, plus design and bend stock bracket
with vice etc, for access to wiring harness and tidy job]..
for a rough but quick replacement tho, this was easy,
giving a better louder horn, for $17 all up
