Its made by honda, got it from my local honda dealer but sadly only for the indian market.nice, where did you buy that headlight?
The one that came on the bike had halogen which was pretty weak on the high beam. This one is led and has a much more "focused" high beam which goes pretty far.What is difference between that headlight and one that came on bike?
For the headlight there's some wiring required but you won't have to cut the main wiring harness. For the indicators it's plug and play.What is the price...can we plug in directly without any wiring work..
Headlight price 6500. Indicators price 550 each, Total 2500 including the mounting rubber and bolts.What is the price...can we plug in directly without any wiring work..
If you need any help with the wiring do ping me. ✌🏻Thnx...looking forward to inatall thos
Yes, all of the current switches work including on/off high beam/low beam passing etc. It can be done to any of the cbr as the headlight mounting is same as the halogen one. You will need some time to modify the wires of the headlight that's it@Adithya Pillai are you able to switch on and off the headlight via headlight switch or does it stays permanently on? Also can this be done on 2011 CBR?
Cool, thanks. Also can you help me out with the indicators. Where did you procured them from? what model? Plus I am also looking for aftermarket levers can you point me to right levers?Yes, all of the current switches work including on/off high beam/low beam passing etc. It can be done to any of the cbr as the headlight mounting is same as the halogen one. You will need some time to modify the wires of the headlight that's it![]()
The indicators are from Hornet 2.0 regarding the levers i would suggest you to keep the original ones or even change them to black levers from HERO which are pretty much identical but only differ in color. The reason why i am saying this is because i have used aftermarket levers in the past they do work alright but the brake lever always feel too spongy (no its not because of air in the system) it feels a lot weird. If you're okay with that then you should look on Aliexpress for aftermarket adjustable levers for CBR250r.Cool, thanks. Also can you help me out with the indicators. Where did you procured them from? what model? Plus I am also looking for aftermarket levers can you point me to right levers?
I bought the ones in the picture below - Long Levers (Link to AliExpress, and another Link to YouTube), and I found the quality to be reasonable, it turned out very nice, they are very comfortable. At this model I did not feel the problem of the flexibility of the metal as claimed by Adithya Pillai.If you're okay with that then you should look on Aliexpress for aftermarket adjustable levers for CBR250r.
