I suggest you check the battery first. It often happens with amateur mechanics, it happened to me too, that they neglect the battery test, then start chasing a problem that doesn't exist and replace parts without it being necessary.
All three battery tests are performed on the battery terminals with a voltmeter:
- The voltage after charging should not drop below 12.7V.
- Measure volt drop when starting, and the voltage should not drop below 10V.
- And if the engine starts, then measure voltage at idle rpm and it should be ~13.9V.
Regarding the coil (
I have no experience),
it's only according to the Hodas book chapter 18.
- The voltage on output (the plug side) should be around 100V. 💀☠You can be electrocuted☠💀, so you have to approach this test very carefully. I have no idea how this measurement is take. It is a voltage that is applied for a fraction of a second.
- The voltage on the input terminals should be the battery voltage? approximately 12.7V?
- If during start-up the voltage on the input terminals drops to 2-4V it is not good...then You need to check the wires backwards (this is not a problem with the coil).
One coil wire is
light green, it is connected on his other side to the ECM. It's the ground.
The
black/blue wire is the voltage wire.
It is not written at Hondas book, if it is important to connect the two wires in the right order? They are both connected to the coil, so I assume/guess there shouldn't be a difference.
