If that's the drainplug, the gasket may be leaking.
If you haven't already - change the oil and filter. When you do, install a new gasket on the drainplug. Clean the area well so you can keep an eye on it. Snug the plug down, but don't get carried away.
I'd recommend using Shell Rotella T5 10W-30 in it. Be careful when you install the oil filter. If it's installed backwards, which it can easily be, it will toast the engine.
