1 - 2 of 2 Posts
Replace oil fiter also,accidentally put 1700 ml...sud i be worried.... Any suggestion??
Thnx
Thnx
For engine oil and filter oil replacement the quantity is 1.5 liters of engine oil.
But Check The Level! (When the motorcycle is standing straight. Engine off)
Automotive lighting Automotive tire Red Rim Gas
Maybe it came out less than you think, maybe it came more, you will look at the inspection window and if you need to take some oil out there are two methods for this:
1. Pump out excess oil with a syringe and a tube of the appropriate length that is inserted through the open oil cap.
Automotive lighting Automotive tire Motor vehicle Automotive design Font
Hand Automotive tire Wheel Motor vehicle Tire
2. Carefully open the drain bolt and release a certain amount as needed(When the engine is cold).
1 - 2 of 2 Posts
