So I wanted to change the color from silver to black, or maybe red? Never done anything like that though, what do you have to do to get it right? I assume there's more to it then taking it off and hitting it with a can of spray paint.
That looks pretty nicehere you go
exactly.wash the shield in soapy water, rinse completely. you can fine sand, then hit it with BBQ black paint, or flat black header paint. rememer 2 thin coats are better than one fat glossy one.
Yeh I think the thing to note here is you want to get a paint that can resist high temp. Correct me if Im wrong, but i believe BBW paint will and black header paint DEF will. I would suggest going to a local auto parts place and ask them what they have that can resist heat.wash the shield in soapy water, rinse completely. you can fine sand, then hit it with BBQ black paint, or flat black header paint. rememer 2 thin coats are better than one fat glossy one.
i've found that you usally get a minimum wage answer whenYeh I think the thing to note here is you want to get a paint that can resist high temp. Correct me if Im wrong, but i believe BBW paint will and black header paint DEF will. I would suggest going to a local auto parts place and ask them what they have that can resist heat.
