1 - 5 of 5 Posts
The one with the plug thing in the end is the crankcase breather hose, one will be the drain from around the fuel cap and I think one is from the coolant expansion tank but I can't remember where the other one is from.
I don't think there is an issue with the number of hoses (they are all vents or drains), but I'd want to know why they are all wet and rust-colored seeing as how the chain looks dry.
If you just got this cycle, I would start looking things over. Check and most likely change the oil and filter (be careful, read some threads here about the oil filter install), check and clean the air filter, check the chain adjustment and lube, check the coolant, check the brake fluid, look inside the tank for rust, etc...etc...
Depending on the year of the cycle, the tires may need to be replaced. it doesn't matter how many miles are on the cycle or how much tread is on the tire. They get old and should be replaced. 5 years is usually the limit.
1 - 5 of 5 Posts
