1 - 20 of 24 Posts
I noticed a new rattling noise on my bike and was wondering if this was a problem. I hear it only around the 3000-5000 RPM range. The rattling noise gets slower or faster as the RPMs change. It's the same whether it's moving or revving while standing still in neutral. The noise goes away when the engine warms up.
I noticed the noise after getting an oil change. I'm not sure if it's related to the service. The oil level looks its on the upper line of the sight glass, maybe slightly above.
Any thoughts on whether is something to be worried about?
You may also look at the cam chain tensioner. It's generally noisy at lower rpms.
Discussion Starter #4
Thanks for the tips. I still have the rattling noise even when the bike (and therefore chain) is not moving, so I think the problem is probably not with the chain.
The big thread about rattle has a long discussion about many different potential causes. One idea that caught my attention was that incorrect valve clearance could cause a rattle. I'm not at the 16,000 mile mark for a valve clearance inspection but well past the time recommendation in the manual of 24 months. Is it worth checking now? I have about 12,000 miles and owned this bike about 6 years.
Mufasa was talking about the cam chain. That is a part of the engine and moves when said engine is running.:wink2:
Usually valves that are out of adjustment make a "ticking" noise, not so much a "rattling" noise.
How long does it run before it stops making the noise?
Any idea what oil they put in it?
If it was mine, and I wanted to know everything was OK, I'd drain the oil (looking for any metal chips) and check that the the filter was in correctly (I'd reuse it), then fill with Rotella T5 10W-30 blend.
I'd probably also check the valves.
If both checked out fine, I wouldn't worry about it.
Rattling sound after an oil change is normally the oil filter fitted backwards and the engines wrecked through reduced lubrication.
Right - I would want to check the oil filter right away before starting the engine again.
If they (shop) installed it incorrectly there's going to be a problem.
They used Spectro 4 10/40. Within about 5 minutes after starting up the noise goes away. The oil change was just over 2 weeks ago, and I have been riding almost every day. I don’t remember if the noises started immediately after the oil change.
If I can get a good audio recording of the noise I’ll try to post it here. I need to buy a few things before I can drain the oil (funnel, bucket, new oil).
You wont need to drain the oil to inspect the filter. there is only 1/2 a cup full in the housing.
Rest bike on the side stand, remove RH faring and belly pan, 4 bolts for the filter cover, have a catch pan under the housing to catch any dribbles.
Reactions: jkv357
That oil is fine, and won't cause any problems, though I prefer 10W-30 (Rotella T5) for the CBR. As noted, no need to drain all the oil or replace it. Just make sure it's always up to the proper level. That's critical with the CBR.
Pull the oil filter cover and have a look. If it's like my CRF150R filter it will say "This side out" or something on the filter. Hopefully it's in correctly and you can check that off the list.
Discussion Starter #13
Is the amount of oil that comes out when I remove the filter enough that I need to add new oil in there?
I don't know, if he rode the bike every day for two weeks I doubt it could be the oil filter. Wouldn't that have shot the engine by now?
Rattles that stop after a short period of running are usually heat/expansion related, so piston slap maybe?
That's probably true. I don't think it will run that long if it's not correctly installed.
I'd just want to know for sure, since he said it started after the oil change.
Discussion Starter #18
I checked the oil filter; it was installed correctly. Is the valve clearance the next thing to check?
Wouldn't hurt to check it, but the 600-mile valve check was mostly needed on 1st year models and even on those many times they were found to be in spec with no adjustment needed. That was the case on my 2011. The manufacturing problem that caused some valves to need adjustment after 600 miles was addressed in later models from info I've seen here on the forum. Then again you don't know how the previous owner rode it, so it would be good to do for peace of mind if nothing else.
Discussion Starter #20
I bought this bike new in 2012 so there's no previous owner. I did have the valve clearance checked at 600 miles but no adjusted was needed. What kind of riding causes the valves to drift? I have about 12K miles on it.
1 - 20 of 24 Posts
