1 - 4 of 4 Posts
After installing the fender kit all of the lights are operational except the plate light. The brake light illuminates with the front brake squeezed but does not with the rear brake depressed. I looked in the manual and did not see a wire diagram.
What did I screw up? With the HB kit, all of the wires are smashed together which leaves hardly any room to unplug and fix.
Discussion Starter · #2 ·
^ Anyone? I checked the wires and nothing looks out of place. The dealer was no help over the phone. Anyone feeling generous enough to snap a photo of their wires under the back seat to help a brotha out :D ?
Brake light - Adjust the rear brake light switch, its hiding behind the peg system, its a little plack plastic threaded thing.
Are you using LED rear brake light, If so, reverse the polarity of the wires and it should work.
1 - 4 of 4 Posts
