1 - 9 of 9 Posts
Hey guys,
I'm about to replace the brake fluid on my cbr250r abs. I know how to do the front brake but just have a question with the rear. Because the rear brake pedal activates both front and rear, do I bleed the front and rear at the same time, or (as someone has suggested on this forum) do one at a time (ie. front first using pedal, then rear)?
Thanks
Victor.
... front first using pedal, then rear...
Can't see any reason, why you should do it any different!
At a car, you start with the wheel, behind the longest brake line. 2. the one, with the second longest, and so on.
The front pipe/hose is the longer one.
After you've done that, do the rear.
I'd guess you bleed the rear brake from the front calliper bleeder and then the rear, all by pumping the foot pedal.
Hi! Sorry for re-use this thread..
I would like to know the diameter of the bleeder screw in order to buy the correct flexible hose. It's about 8mm?
Thanks in advance, Cheers!
IIRC, 1/4 inch fuel line works.
Reactions: CarlosPRT
1 - 9 of 9 Posts
