1 - 11 of 11 Posts
Hi,
New motorcycle owner, and my first refuel was just the other day. I noticed I am not able to insert the nozzle fully into the tank like I do with my car, as there is some sort of metal bar right at the tip of where the nozzle should go. I had to pull back on the rubber piece of the gas nozzle to make gas flow. However, this way I can actually keep an eye on the fill level. My question is, should I be able to insert the nozzle fully and be able to tilt it down to utilize the automatic cut-off or not?
Yeah, it's normal. I have to do the same with my bike.
I keep a 5 gal. container in the garage for the bike. Fill it up when I fill the car. I always leave the garage with a full tank. (Haven't done a 200+ mile ride yet, to have to fill it at a station).
Thanks everyone!
Feather the pump lever as you would the clutch. Hold the nozzle in the tank to fill. Should only take roughly 1 minute to fill.
Fill it to the bottom of that metal tab you see there, though I fill it a smidge over because with the bike upright, the fuel levels back out.
Some gas stations have touchy (aggressive) pumps so it's difficult to avoid that light spray back. Others have a smoother delivery. Take your time. It's a small tank so it doesn't take long to fill.
Hi,
as per design.
If you were able to insert the nozzle fully, the back pressure would activate the automatic shut off continuously.
even with the nozzle only sticking in the hole an inch, the automatic shutoff still works when the tank gets full..but i wouldnt hold the handle fully in or locked fully squeezed in..even with the handle barely squeezed, gas will splatter back on the tank..just the way it is..ive tried every way I can think of to avoid that..but no go so far
Lol.
1 - 11 of 11 Posts
