1 - 7 of 7 Posts
Just recently did an oil change and decided to keep the old gasket. There is a very minor leak (no drips) and I'm ok with that, I have no tension wrench just being careful to not over-tighten. Any reason why I can't keep the gasket if it looks ok for the next change also?
I usually flip the gasket over and get a new gasket every other oil change. Never had a leak.
The CBR250R/300R oil filter gaskets have an asymmetrical shape, as shown here... https://www.partzilla.com/product/honda/15412-KYJ-901
So no, they cannot be flipped over and reinstalled that way.
Yes, they can only be installed one way....unlike the oil filter.
I always install a new gasket. My local dealer doesn't stock them and I don't want to be waiting on a parts delivery if the used one starts leaking. What the heck...it's only a $4 part.
If the gasket is leaking now (even a little) then certainly you do not want to use it on the next oil change also? That would be a bad idea.
Just buy some gaskets at the dealer or check this out Magenetic plug + a washer for $5 shipped from China:
https://www.ebay.com/itm/For-Honda-CBR900RR-Engine-Magnetic-Oil-Drain-Plug-Anodized-Crush-Washer-M12x1-5/182788101482?fits=Model:CB300F&hash=item2a8f05156a:g:EXoAAOSwSblZsd6G:rk:1:pf:0
For myself I did this:
https://www.ebay.com/itm/CBR250-R-CRF250-L-M-OIL-FILTER-X3-GASKET-X3-CRUSH-WASHER-X3-2011-16-GENUINE-OEM/173751457591?hash=item287464d737:g:JCEAAOSwYUZcJJ0O:rk:1:pf:0
Although I myself have a CB300F so im not sure if the same part fits both bikes. But I recommend just get a vlue pack on eBay shipped from Thailand of the Honda branded filters + crush washer + rubber gasket seals. And in my case I use the same rubber gasket 2 times and probably you can get 3 uses out of the metal crush washer if you are gentle with the oil change procedure
1 - 7 of 7 Posts
