I was reading "Riding in the Zone" by Ken Condon last night, and he had an interesting way of talking about braking and turning. It's a good book - glad I added it to the collection.
Anyway, everything from MSF up tells you to brake before you turn, and this is the "gospel", so to speak. However, many people still don't really understand the destabilizing force that braking adds to the equation.
I think Condon does it perfectly with the concept of the "Traction Circle", namely:
None of this is to say you cannot brake in a turn - but it shows that the more you brake, the less you can lean. The maximum lean angle can only be had with no brakes, and maximum braking with no lean. Obviously, better tires and suspension will make the circle bigger - but the same proportional restrictions apply.
So what does this really mean? Bottom line is that taking a corner starts well before you start to lean - you should be judging the corner and setting your speed up with the bulk of your braking before the turn. That way, you can coast through the turn or, even better, add throttle to lighten the front / load the rear so the bike will track better.
Condon's book goes over this concept in more (and better) detail, as well as providing a wealth of tips about staying safe on the street. It also includes a DVD that reinforces the concepts in the book.
Good Read!
Luke
- The black circle represents the limits of traction
- The red arrow is braking force
- The green arrow is lean angle
- The blue rectangle represents the force of the braking and lean vectors.
Good Read!
Luke
