Controlla le distanze tra i pneumatici e assicurati che i perni delle ruote siano diritti e posizionati correttamente. Sollevare le ruote e farle girare a mano, ascoltando i rumori di sfregamento o eventuali inceppamenti delle gomme o dei freni. Un rumore che senti quando la bici è fredda può scomparire dopo che le gomme si sono riscaldate e stai guidando.Motosiklet soğuyunca sürtme sesi geldi ama ısındıktan sonra bu ses gitti, sanırım eksantrik bir sesti, ne dersiniz?
A noise you hear when the bike is cold can disappear after the tires warm up
Yes, good thought, thanks! it is possible for a screw that came loose inside the engine to start making this kind of noise, and such are the screws that are holding the coils (stator), it is very uncommon, but it is possible.Make sure to check the magnet coil screws roaming inside 🔩🌪⚡😂
Hey Tamir, how do you inspect and/or replace the rubber slider? I do not know the condition of mine and tried to inspect it for wear, as stated in the service manual (or owners manual, not sure off the top of my head). However, I am struggling to see anything behind there, even with a flaslight. Do you have any tips?
You're right, I'm guessing the previous owner of my motorcycle didn't see either, and therefore didn't check. I guess the noise of the rubber coming off startled him fairly. In the Honda manual it shows the point that needs to be checked, but in the manual the side of the frame is drawn when it is transparent. In reality the frame blocks the line of sight. You have to look at the check point from the other side. Maybe later today I'll post a picture here that explains how to look at the inspection point.Hey Tamir, how do you inspect and/or replace the rubber slider? I do not know the condition of mine and tried to inspect it for wear, as stated in the service manual (or owners manual, not sure off the top of my head). However, I am struggling to see anything behind there, even with a flaslight. Do you have any tips?
Exactly. I am not sure how to get it off either.In the Honda manual it shows the point that needs to be checked, but in the manual the side of the frame is drawn when it is transparent. In reality the frame blocks the line of sight.
Why did I not come to this forum earlier... Checking it from the other side never crossed my mind. However, I am still struggling to see if it needs replacing or not.In reality the frame blocks the line of sight. You have to look at the check point from the other side.
Wait, I checked, My Mistake, the mark on the rubber of the slider appears only on the left side, so it doesn't help to look at the slider from the right side. So you have to make an effort, and if you know what to check and what sign to look for, it's really simple. I will upload pictures soon.Checking it from the other side never crossed my mind. However,
If you have a little patience, wait for the pictures that I will upload here soon.Exactly. I am not sure how to get it off either.
My rubber has most likely gone only 14k kilometers, but it is most likely 11-12 years old. I ordered some other parts earlier today, so I have sent an email and asked if I could cancel the order, so I can place a new one with this rubber slide thingy. Hopefully they'll let me cancel my last order, so I don't have to pay for shipping twice.In my estimation, my rubber broke around 50-60k kilometers.
If the shipment does not go out they will be happy to give you this service. I don't remember being asked to cancel. Customary thay send a link to make the payment for the additional part. This is what I know.Hopefully they'll let me cancel my last order, so I don't have to pay for shipping twice
Yes left side of the bike.Do you have any tips to see the wear indicator on the "correct side" (left side of the bike)?
If you have patience, I believe that in the coming days I will finish editing a video on that subject.I can't find anything on it in either the haynes or service manual.
It's very easy to replace this rubber under the chain, mine got damaged just in 3k and I replaced it my self it's only INR 100 just u have to open where the 14 teeth chain sporket is located then lock the rubber there it's very easily and I also change fule pump motor that was easy to fit in pump assembly but it was hectic to open gas tank, fuel pump assembly and restore it back fuel pump motor cost me INR2699 from Amazon it can fit in bullet thunderbird 500 tooIf the shipment does not go out they will be happy to give you this service. I don't remember being asked to cancel. Customary thay send a link to make the payment for the additional part. This is what I know.
I arranged two pictures that explain where the minimum line is. Maybe later this week I hope there will be a video:
Yes very easy to replace, very easily, easy to fit in...It's very easy to replace this rubber under the chain,... it's very easily and I also change fule pump motor that was easy to fit in ...
Yes ONLY 2700INR (33USD)???... fuel pump motor cost me INR2699...
