The pics attached show how I support my soft luggage to prevent it sagging in towards the wheel.
Made from 30x3mm steel it is supported behind the rear footrests and from under the rear seat.
Under the rear seat you will see two bolts which support the rear light cluster.Remove these and drill through for longer bolts to pass through the plastic .Then you can bolt the new frame to these above the rear wheel.
Hope the pics explain better
