Bonificus, Welcome to the forum, and thanks for sharing and the video. Excellent video.we’ve charged the battery
I checked it out and when the starter is pressed it drops to 6.3 V, I believe the battery is under warranty so I’ll replace it today. There may be another problem as the bike died while I was driving, and the battery status shouldn’t have affected that no? I’ll keep you updated after I replace the battery. ThanksBonificus, Welcome to the forum, and thanks for sharing and the video. Excellent video.
Why should I be the bad gay? Dear friend, I think you need a new battery. And I'd love to know I'm wrong.
Immediately after you turning on the starter you have a strong voltage drop. This is typical sine of a dead battery situation. I would say a short, but all your fuses are fine and you have no problem going back and reproducing the fault. So I think it's not a short.
In the past I fell with a new battery, and entered a loop of unnecessary expenses. It's that simple to test a battery. So I suggest you check her out and let us know how she is doing.
For this test you need a voltmeter.
1. Voltage on the battery should be at least 12.7V (less than this requires charging).2. Measure voltage on the battery during startup. The voltage should be above 10V (If the battery does not hold 10V it means it is a dead battery).3. If the engine starts, check the voltage on the battery terminals again, it should be around 13.9V (if there is less, it means there is a problem with the coils of the generator).
Well I replaced the battery and the problem persistsI checked it out and when the starter is pressed it drops to 6.3 V, I believe the battery is under warranty so I’ll replace it today. There may be another problem as the bike died while I was driving, and the battery status shouldn’t have affected that no? I’ll keep you updated after I replace the battery. Thanks
I'm guessing your battery was destroyed by a charging system that stopped charging. You can check if there a short on the coils, but sometimes there is no measurable short, and the coils are not normal, and the generator does not provide a high enough voltage to allow normal charging. If the battery is destroyed as a result of a previous failure in the charging system, I'm not sure it's under warranty. It's really annoying, but it could happens sometimes.There may be another problem as the bike died while I was driving,
Please don't check by changing the battery, check ONLY by the voltage level during startup.Well I replaced the battery and the problem persists
Do not use a car battery, it has an amount of current available that can only create new problems.Can you jump-start it with a car?
I used to think the same thing, and it's sorta true. 12V in a motorcycle battery is the same as 12V in any other battery, no matter how large or small. You could jump a small vehicle (a 250cc motorcycle) from a larger one (a car), but you wouldn't want to go the other way around. If the vehicle is going to draw more amps than the battery can provide, then that is where you will run into problems.Do not use a car battery, it has an amount of current available that can only create new problems.
Yes AND NOoooIf the vehicle is going to draw more amps than the battery can provide, then that is where you will run into problems.
If you short a battery, even a motorcycle battery, the current rises to the levels of arc welding. That's not what Bonificus said: And his fuses are fine.A 3rd alternative is to see if there is a short in the wiring?
YES ===>>> Volt/Resistance=CurrentVoltage = Current * Resistance
CBR250R battery as only 6Ah <<<< 55AhCar battery : 12v 55Ah
And your conclusionI just bought. Bike fell over and has been causing problems since.
There is no connection between the two events. No way.Turns out it’s a broken crankshaft.
Sorry to hear that.Turns out it’s a broken crankshaft.
