1 - 6 of 6 Posts
My CBR250R is a 2013, I got it four months ago with 7k miles on it and it now has about 11.5k miles on the odometer. This is my first bike, but I drove a manual transmission since 1996 so I could "ride" immediately. I dont feel like I burn the clutch or anything, I do ride it pretty hard, but for the first few months I never got false neutrals and now I get them kind of regularly. Can anyone tell me what might be going on? Thank you in advance this site is an amazing resource.
Oil needs changing?
Clutch-lever needs adjustment?
Make sure both the arms coming off ball-joints on shift-rod is 90-degrees to rod.
Oil needs changing?
Yeah I think the clutch lever got moved somehow. I will check the arms coming off shift rod as well. Clutch plates shouldnt wear out at 11.5k miles under normal circumstances right?
You may need to lube the shift linkage pivot points.
Check the adjustment on the clutch cable/lever.
Try a different oil. Rotella T5 blend in 10W-30 is a good choice for the CBR IMO.
Be careful when you install the oil filter that it's facing the correct direction.
There is a non-mechanical cause for false neutrals; lazy foot (or ankle) syndrome, especially on the first to 2nd shift as the lever throw is a bit greater. I found myself guilty of that on a CB500X in my later 70s.
1 - 6 of 6 Posts
