I get free bcs warranty engineer check bike,at least they found the problem. are they still covering it for you though or they making you pay?
can still use bike ok ,just take 4 times to start when coldThey give you a replacement until it's fixed?
I get a Scoopy-i when mine is being serviced.![]()
I am having that problem..well did anyway..would crank and crank but not fire up..started when weather turned cold...sometimes took several minutes of cranking..I read online a trick to try..now i prime the fuel line 3 times before I try to start if its been sittin awhile...a litle twist of the throttle at the same time and it now fires up ok...can still use bike ok ,just take 4 times to start when cold
