I sprayed mine with lock tumbler spray.Lately I've had to push and jiggle the key a bit to to unlock the forks. Anyone else have this problem? Is there a trick to making it less likely?
Yeah I could barely get the key in once. Sprayed WD40 on it, worked.I sprayed mine with lock tumbler spray.
+1 - key hard to get in and also turn if you don't have the steering as far left as it goes.If you have not got the forks all the way to the left when they are locked it will cause some issues turning the key
