Go for a ride to warm up the engine and do an oil/filter change. (Acids develop in oil as it gets old and used.)
Drain the carb. After that, I usually squirt a little WD40 back up the drain and let it drain out.
Take out the sparkplug, put a little 2-stroke oil in the cylinder and turn the engine over a few times. Turn it to TDC (tod-dead-centre) and put the plug back in. (2-stroke oil is designed to burn off clean when you next fire it up.)
Change the old brake fluid (it has slowly been absorbing moisture).
Service the chain.
Drop tire pressures to about 25-26 lbs.
Check battery fluid and put it on a trickle charger.
Have a beer.
Service the chain.
Have a beer.
