I cropped the rear fender. It looks much better now and it is very easy. Should go through the air better now too. Remove the stock plate bracket. Just mark a line from the lower round mount area up on an angle to one of the features in the moulding to get it even on both sides. The plastic is very easy to cut with tin snips and smooth with a file or rotary tool. The plate will mount right to the holes that used to hold the bracket. You can glue the stock side reflectors back on somewhere if you want to keep it legal. I will use some DOT red reflective tape on the sides of the plate light housing.
