sorry if I'm starting to many threads I was just curios if anyone else had an issue with their coat zipper making small scuffs in the gas tank and how I can prevent this?
Actually i have never had any problem at all getting them back off. Piece of cake get a corner started and peel it offSomeone here had a good idea of Not putting a tank protector on till you sell the bike, that way it hides the scratchs. Instead of when you sell they see scratched tank protectors that are hard to get off.
Did you get the 3M from Tankslappers? If so, does it cover the entire tank or just the top? If not, from where did you get it?3M. I like the clean clear look which helps with further mod styling you may wish to go with along with any possible resale. I've done this with my last two bikes and am completely pleased with it.
Yup, I've removed lots of protectors from bikes. I usually heat it with a hairdryer and it lifts right off. They're easier to remove than all the safety stickers that come with the bike, at least in my experience.Actually i have never had any problem at all getting them back off. Piece of cake get a corner started and peel it off
Yes, from Tankslappers. I had it put on at the dealership when I purchased the bike and it covers only the bottom half, not the full tank.Did you get the 3M from Tankslappers? If so, does it cover the entire tank or just the top? If not, from where did you get it?
I'm a little worried because I already have a scuff mark on the top of the tank, but I'm hoping that it will rub out.![]()
So do you still have your tankslapper installed? How is it holding up?Yes, from Tankslappers. I had it put on at the dealership when I purchased the bike and it covers only the bottom half, not the full tank.
