1 - 13 of 13 Posts
Hello all,
I recently installed a dynojet power commander 5 with an auto tune kit on my 2012 CBR 250r ABS. I am trying to find any literature on the target AFR for the stock honda, so I have have a base map for the auto tune to work off of. Ideally I would like a base map for for the pc5, taking into account I have a high-flow K&N air filter and a full akropovic exhaust installed on the bike, but beggers can't be choosers. Anyone with knowledge on the subject I would greatly value your input. Anyone that would like to offer their opinion on the mods I have chosen to spend MY money on, please divert your energy into a more useful or valuable subject.
Thanks,
Adam
44564
Don't run Premium gas. The only reason for more octane is to prevent detonation. The only way that would be an issue is if you were to bump the compression ratio with a different piston or headwork.
For max power, you want the lowest octane gas you can use that just barely keeps detonation away.
An optimum dyno tune on standard gas will get you the most power. You also want to know where your new HP peak is after doing your mods, because it has most likely moved upward in the RPM range.
Thanks for the reply moto Mike. My problem is I don't have access to a dyno in my area. I live in northern Ontario canada, that's why I went with the auto tune. My pcv didn't come with any maps on it for some reason so I have no base map for the auto tune to work off of. Right now I need to get my auto tune running before I start tinkering around with changing octane and what not. I will definitely keep that in mind for the future.
You should be able to download an appropriate map on the PC website.
We had a PC on my son'r R6, and tried a few different maps until we got one that worked best. The only way to get it totally optimized is on a dyno, but if you can try a couple different maps you should be able to find one that works well enough.
Discussion Starter #7
Yea...that was the first place I looked, since it was supposed to come with one or two maps on the unit it's self. There is no option for a cbr250r. There is almost any other bike honda makes, besides the 250. Saw some 125's and even a grom on there. I tried calling them to and they are baffled that I have one for the 250r. They can't find anything on ever selling them for a cbr250r. That is why I figured I would try on here. Trust me when I say the pcv and auto tune was not cheap, and to be stuck with no base map really sucks.
That does suck.
You would think they could do something to get you on the right track.
Are you sure you have a CBR250R unit?
Discussion Starter #9
Yes sir... bought it from fortnine.ca...had the instructions with pictures for installing it and everything. Yeah the description said it came with a base map pre installed on the unit. Would have never thought I would be in this situation when I purchased it.
Discussion Starter #10
My mistake I bought it from revzilla.com
Discussion Starter #12
I called them today..they used the part number to find a map on the dyno jet website called a zero map. It is literally all zeros. :(
Big help - huh?
I'd call Dynojet and keep moving up the food chain until you get answers.
Most likely the CS person that answers the phone doesn't know squat, and you are going to need to find someone in technical service that is willing to find answers.
Probably gonna need to push a bit.
1 - 13 of 13 Posts
