1 - 20 of 129 Posts
Dupont Teflon Chain saver (wax) Every 400-600 miles, depending.
+1 .... i use dupont chain degreaser first..let it sit one minute then wipe off..think i may try my pressure washer next time tho..wiping with a rag still leaves a lot of residue on chain in the nooks and crannies
I use Bell-Ray blue tac it seems to work well....I lube the chain about every 500 miles.
Liquid Wrench every 500.
doesnt that sling all over the back tire and rim like fricken crazy? i used to use just generic o-ring lube to begin with..just like wd-40 and liquid wrench it stays wet....that crap always left a huge mess on my back rim..had to wipe it down with an alcohol soaked rag once a week to make it silver again
switched to dupont chain wax= no splatter at all since it dries to a clear film on the chain
Banned
I spray on a quick splurt of lube when I get home every evening.
Once a week when I wash the bike I deep clean the chain, particularly focusing on wiping/cleaning the chain slider, you need to lift the chain up and really get yer fingers in there.
To each their own.
I haven't had any issues with it yet. I even used it on my clutch lever because it was snagging up a bit. It is the chain lube kind not the bolt seize.
+1
I use wd40 and a wire brush then some liquid wrench and that chain might as well shine. did my first lube today and went for a ride and it also quieted some chain chatter. perfect :cool:
Dupont Teflon Multi-purpose lube. Cleans and lubes, works like a charm. Also great for firearms...
I usually clean and lube our bikes at least once a month. My wife and I tend to attract rain it seems.
Chain saw oil, applied with a tooth brush. - Even cheaper.
I use whatever is available, whenever necessary.
Yes folks, chain saw chain oil is sticky and works well. I used it before spray on lube became available on the market, and would again.
Spray on chain lube of any brand is best, but with a can lasting quite a while I have no real basis for comparison, except than that it works better, lasts longer, and is more convenient to use than oil.
Where I am now a can of chain lube costs an expensive 800 baht (about $US 25.00). Ordinary oil costs nix and works just fine, though needs to be applied a bit more often. I don't muck around with cleaning. For my current ride a standard (non O-ring) chain and sprockets costs about 550 baht, and is good for 25,000 to 30,000 km. (15-18,000 miles)
1 - 20 of 129 Posts
