loose-ness of the throttle. I have a little play before the bike responds to the throttle pull.
It is part of the initial dealer setup checklist. It changes overtime (more freeplay) due to the cable stretching a bit. The clutch cable stretches also, even more so. I like to have the throttle adjusted so there is almost no play at all....but you want to make sure it is coming up against the throttle stop first! ( ie , all the way closed). .......i would think thats somthing the dealer should do for u,for buying the bike,good bizz![]()
May2nd,as a realativly inexpierienced rider, i tend to kind of open the throttle up when i go to grab the front brake. as we all know, that is a dangerous habit and i am trying differdnt ways to grip the throttle but does anyone have any insight into what a possible solution may be? and has anyone else had this problem when first learning to ride?
I haven't used it yet. It is supposed to help u in long rides, wherein your wrists starts to pain. There are numerous uses, u can control the throttle with one finger, or with the weight of ur hand, etc.So is that cramp buster just for you to rest your wrist on?
I just got use to it...my throttle also seems sensitive..
