How is your rack-system going? I saw others were having issues with cracking etc...And now, my new top case Kappa 46 liters is installed with the support Givi. What do you think of my new bike ?
Wasnt sure if i was going to get a top box on the CBR. Had them on 2 of my 3 scooters. (50cc-150cc-460cc scoots) Never got one on the 150 because i felt it ruined the look of the bike. Same feeling about the CBR. But i do miss lockable storage so was going to get one soon as the givi was available. but now from reading the above. maybe i will just not bother. I will be on the hwy alot next season and at 100kph + .. get kicked around in the wind enough without it so dont want to add in extra instability.Most days I just take the top box off as it really interferes with the aerodynamics above 100kph. The side panniers are fine up to around 125kph which on the country roads in Indonesia is plenty.
thanks for that !I got mine from here Motorbikes and Parts Luggage Specialsts - Givi Luggage, Bagster Laggage, Kappa Laggage it's the same as the CBR 125R one P/N SR1103. You need to buy the universal Monolock plate as well P/N KP-K628. I've got the Givi E450 top box on mine. Any place that stocks Givi should be able to get these for you.
It's 6KG max load. That's 13.2lbs.im worried about the 6.6 lbs max load, has anyone tested this? im planning on finding a way to reinforce everything
The rack says its 6kg max load but all the monolock top cases say 3kgIt's 6KG max load. That's 13.2lbs.
Anyone have any idea on how to set up these side panniers? I see givi monolock hr4 on them and when searched it looks like they were made for the ninja 250My solution is inclusive of side panniers for touring, as i am a photographer I need to bring gear too so I ended up with v35s as well. Anyway everything hangs off the longish monorack for the topbox, which bolts to the pillion pegs and the grab handle bolts. I felt that anything that hung off just the grabhandle bolts would be flimsy, and I had also to think about the turn signal lights once the panniers were installed so I moved them up under the rack for the top box where they are visible. As my top box has an active brake light I didn't worry too much about the two pieces giving the top box extra support (if you don't they bounce like h..l, plus this way you can go a little over the 3 kg load limit). Most days I just take the top box off as it really interferes with the aerodynamics above 100kph. The side panniers are fine up to around 125kph which on the country roads in Indonesia is plenty.
Yes, you're quite right. Thanks, I didn't notice that. I think you'd be OK going a bit over, as long as you don't put a silly amount of weight in it.The rack says its 6kg max load but all the monolock top cases say 3kg
im more interested in the side rack set up if you have any ideasYes, you're quite right. Thanks, I didn't notice that. I think you'd be OK going a bit over, as long as you don't put a silly amount of weight in it.
Actually The panniers have a recommended weight of something like 10kgs if I remember correctly.Yes, you're quite right. Thanks, I didn't notice that. I think you'd be OK going a bit over, as long as you don't put a silly amount of weight in it.
1.The monorack is the GIVI HR4, not sure which bike it was made for actually.Rio,
1) Which monorack system (fit what bike) did you modify to fit the CBR250r ??
2) Why couldn't you move the panniers forward a bit so they didn't stick out the back so far ?? (so a guy could leave signals in stock location)(Was exhaust in the way ??)
I totally love the set-up and would love something simular on my bike !!
Thanks
Ive got a 52L givi top box, don't notice any instability or turbulence. It was on the bike when I took it to redline at 165KPH.Wasnt sure if i was going to get a top box on the CBR. Had them on 2 of my 3 scooters. (50cc-150cc-460cc scoots) Never got one on the 150 because i felt it ruined the look of the bike. Same feeling about the CBR. But i do miss lockable storage so was going to get one soon as the givi was available. but now from reading the above. maybe i will just not bother. I will be on the hwy alot next season and at 100kph + .. get kicked around in the wind enough without it so dont want to add in extra instability.
Hmm that's interesting. On my last long trip I was riding thru heavy winds and a couple of times went quite close (1.5m) to trucks barreling down the road in the opposite direction. Normally just by tucking in a little bit I'm ok but with the box I could feel it catching the back. Mine is a smaller box too than yours. Interesting.Ive got a 52L givi top box, don't notice any instability or turbulence. It was on the bike when I took it to redline at 165KPH.
Love the box cuz it stores two full face helmets and some gear securely. Recommended.
