1 - 7 of 7 Posts
Can someone with a US service manual look up which wire is the tail light and which is the brake light?
There's a green wire, a green with yellow stripe wire and a light brownish/red wire.
Poking through with the tester will be my last resort.
Any assistance would be appreciated.
G/Y COMING FROM BOTH BRAKE LIGHT SWITCHES, to tail light. BROWN GOES TO TAIL LIGHT AND LICENSE LIGHT.
oops, sorry about the caps. I'll take a double check for your sake. I have not done my elim. yet.
Thanks. So the brown is what I want to power my relay.
In hindsight I should have been able to figure that out. Two green wires, two brakes (front & rear). My brain no worky today.
Thanks Brian,
it would have sucked if I hooked the relay to the brake light.
I'd have power only when applying the rear or front brake depending which wire I used :D
I have successfully hooked up my relay and have hooked up a nice set of heated grips and a SAE pigtail for my heated vest.
I am ready for winter :)
1 - 7 of 7 Posts
