1 - 14 of 14 Posts
My psi in front is 29, rear 39, nothing wrong with the tread....so what could it be that make it feel like im going to slip out when turning? (I serioiusly caught it this last ride)
Probably too much pressure in the rear tyre. There's no way I'd be running 39 in the rear, try dropping it down around 32 or even a bit less and see how it goes. Are they the original tyres or new ones?
As bods suggested - rear pressure is too high. Check the recommended pressure, but i don't think either are correct.
As also suggested - check your tires. What year is your CBR? Do you know if the tires have been replaced?
Tires lose traction from age, not just miles. Tread depth doesn't matter.
Discussion Starter #4
Sorry mistype i have 30 psi in rear and its a 2011 with original tites but less than 3000 miles.
If they're the factory tyres still on it they will be as hard as anything by now. I would look at getting them changed as soon as possible. Most tyres are recommended to be replaced by about 7 years old regardless of how worn they are as the rubber hardens and breaks down with age, especially when they've been outside in the weather...
Sorry mistype i have 30 psi in rear and its a 2011 with original tires but less than 3000 miles.
There's your problem.
It's time to replace them - no question. The mileage doesn't matter.
They are unsafe at this point, and as noted, weren't that great when new.
I've junked new OEM tires with less than 500 mi on them because they were not good enough. Tires are one of the most important items for safety on the road. I've been riding for over 40 years on the dirt, street, and track, and probably wouldn't ride around the block on your tires.
Back tire pressure should be 33 without pillion
2011 CBR250R with the original tires and low mileage just like the OP. I finally swapped out my original IRCs with Michelins this year, mainly because their age was starting to worry me. When I got the rear wheel off the bike I was a little surprised to notice how flat the crown of the rear tire had become, something not really noticeable when the tire was on the bike. I've become a believer that tires should be replaced after 5 years of use, no matter how good they look or how much tread remains.
To add to what members have posted. Start off with the threads, see for one-sided wear especially the front. If you observe the same, replace the tire. Meanwhile, get your coneset/T stem bearings checked. A conked T stem bearings would mean improper steering geometry correction and would lead to a falling sensation. Thirdly, make sure the right psi, 29 in the front is perfect.
Good luck.
Cheers!
VJ
1 - 14 of 14 Posts
