I decided to try raising the quiet spot behind the windscreen with a piece of plastic sheet and it is working nicely.
I drilled 4 1/8" holes in the ears of the stock windscreen. I then used snips to shape the plastic so that, when it was arched to be flat on the ears, it reached the ends of the screen.
I then held it in place while I drilled and attached one top corner of the plastic. I then arched, drilled and attached the other top corner. Finally, I adjusted the angle, drilled and attached the remaining straps. I used tie wraps which seem to work fine and don't put stress into the stock windscreen. It needs some cleanup but I was excited to try it out. This all took about 15 minutes. I think the next one will be an 1" taller and I will cleanup the edges better.
http://www.cbr250.net/forum/attachment.php?attachmentid=430&stc=1&d=1312667851
http://www.cbr250.net/forum/attachment.php?attachmentid=431&stc=1&d=1312667851
http://www.cbr250.net/forum/attachment.php?attachmentid=432&stc=1&d=1312667851
http://www.cbr250.net/forum/attachment.php?attachmentid=433&stc=1&d=1312667851
This will do me until something 'official' comes along. Maybe longer...
